Connection was reset message
Thread began 8/02/2010 11:49 am by john.pike383409 | Last modified 8/02/2010 1:32 pm by Jason Byrnes | 1063 views | 3 replies |
john.pike383409
I am using the SA wizard to generate Login, registration, etc pages and they work great.
All pages generate an error "The Connection was Reset" when information is entered and submitted. I'll use the LogIn page as an example.
I am using root relative links and the table has one record in it. The table integrity is good
I have deleted the Dreamweaver chache, deleted and reloaded WA Cookies toolkit and SA Toolkit.
users_LogIn.zip
when you set the option in the Site definition to Create links relative to the Site, it will cause Dreamweaver to use the following syntax for include files:
<?php virtual('/Connections/MySql.php');?>
The virtual function is not supported by many servers, you should select the option to create links relative to the document instead which will cause Dreamweaver to use the require_once synatx which is supported on all servers.
<?php require_once('Connections/MySql.php');?>
john.pike383409
Good News
That did it. Thank you very much.
John
you're welcome.
