checkout failure and success pages
Thread began 8/02/2010 8:09 am by rob75685 | Last modified 8/03/2010 2:08 pm by Eric Mittman | 1110 views | 3 replies |
rob75685
hi there
I've followed the eCart checkout wizard - for SagePay - which is all working fine, but it doesn't create the success and failure pages for me ?...
Obviously I'll need these to record successful or failed orders.
So have i missed something here?
thanks for your help
eCart 5, CS3, Mac
Did you chose VSP Form or VSP Server? Only if you choose VSP Server will you have the options to create the checkout success and failure pages. These pages are listed on the final page of the wizard.
rob75685
hi Eric
Thanks for your reply.
I'm using VSP Form. I remember using this in eCart version 3 or 4 and it created the success and failure pages for me... at least I think so.
Does VSP Form not return information back to the website then?...
thanks
I have done some more testing and I can confirm that when you use the checkout wizard for VSP Form you do have checkout success and failure pages that are created for you, I'm including a screen shot of the final page of the wizard for reference. You may have altered the names of these pages in the wizard if you don't see a regular checkout_success or checkout_failure page.
As for getting back the response for this type of checkout you can go to Bindings > eCart > checkout > checkout form response then choose VSP Form from the select list. You can then use these values on the page that you are returned to for sending out a receipt or storing info in your db.
