Search Not Working
Thread begun 8/02/2010 3:55 am by hbibizadeh396670 | Last modified 8/02/2010 9:52 pm by Miguel | 3538 views | 5 replies |
hbibizadeh396670
Search Not Working
I have added a search to my site but the search does not return with any results.
I dont know what the issue is so I have added a link to the online page and will also attach the index and results page.
index.php
thanks
you cannot have spaces in the names of form elements.
this is a badly named text box:
<input type="text" name="Search Field" id="Search Field" />
use an underscore instead:
<input type="text" name="Search_Field" id="Search_Field" />
hbibizadeh396670
I made the changes, but it does not seem to return with any results.
Please see link
www.orlando-villa-rental-direct.com/
did you recreate the search for boss results page after changing the name of the search field?
You should recreate the results page, if you are still having a problem, send a copy of your most recent pages.
hbibizadeh396670
ok I have made that work thanks alot
The only other thing is that I have been working on the search and have been trying to find out how to make my search field have rounded corners.
Could you tell me how to do that please, for example the web assist search field has rounded corners
thanks
Miguel
You can use CSS to make round corners here are some tutorials
000044.php
Good luck
