Can't get local checkout dialog to change trigger
Thread begun 6/05/2009 9:32 am by thescrub | Last modified 6/08/2009 9:11 am by thescrub | 2265 views | 2 replies |
thescrub
It seems that no matter what I select when adding local check (authorize) to a page no matter which trigger I select from the dropdown I end up with:
if ($_SERVER["REQUEST_METHOD"] == "POST")
If I re-open the behavior and try and change it I get the same result. (ecart 4.5.0)
Set focus to another field before clicking OK. a bug was introduced into many of our interfaces associated with the CS4 updates we made... now the last field you update may not register unless you click into another field in the interface. It used to work that the button click would act as that next field, but in the new UI it doesn't work quite the same. We will be updating our products to address this issue, but it is relatively easy to work around once you know what to look for.
thescrub
Thank Ray, that worked. Just a new habit to develop.
