Multiple file upload and file management
Thread began 7/30/2010 9:31 pm by paulshoe379536 | Last modified 8/06/2010 10:42 pm by paulshoe379536 | 1066 views | 2 replies |
paulshoe379536
I would like to have a file manager interface that would allow the user to view and delete existing files, create new folders (restricted to a parent) and upload multiple files at one time. What would be the easiest way to accomplish this?
The file manipulation features of Universal Email will allow you to upload and delete files. This in combination with recording the files values and details in a db table with DataAssist could help you achieve most of these goals. You can upload more than one file at a time on a page but you will need individual file fields for each upload. Allowing the users control over creating directories is not a feature of these tools.
To build this out you would probably want to use DA to create all the pages for managing the data and get all that worked out first, then you can go into these pages and add in upload and delete file functionality where you need it.
paulshoe379536
Thanks for the reply. It looks like I will need to look further for a solution. For this application, I need to have the ability to create folders and it would be nice to select multiple files at the same time or drag and drop for uploading. I suppose a Flash, Flex or Java app is needed. I also need set the user's base folder dynamically.
Ideas from anyone appreciated,
Paul
