Powerstore User registration error.
Thread begun 6/05/2009 8:10 am by Scott Noyes | Last modified 6/05/2009 8:22 am by Scott Noyes | 2249 views | 2 replies |
Scott Noyes
When I go to the user registration page I get this error.
Spry.ValidationConfirm ERR. The Element spryconfirm1 does not exist.
When I hit ok the page displays fine. But it should not happen. Where do i need to go to correct this. I have not changed anything on the page.
That would appear to be a problem with the confirm password field. What version of Dreamweaver are you using? This may be because spryconfirm is new in CS4 and you may need to ignore the error or find the downloadable spry update from adobe that may correct the problem.
Scott Noyes
found the problem. The java script needed to be moved to the bottom of the page. When I applied my template it was moved to the top of the registration form.
