Two Domain Names pointing to one site
Thread begun 7/29/2010 10:54 pm by dgwhit288523 | Last modified 8/05/2010 8:57 am by Jason Byrnes | 3797 views | 7 replies |
dgwhit288523
I have two domains pointing to one site with a single directions.htm page. One API key will not work for both domains. Please advise the solution to this.
Thanks,
Don
on your page, you will see a script line that looks like:
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAvZMU4-DFRYtw1UlTj_zc6hT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQcT1h-VA8wQL5JBdsM5JWeJpukvw">/*wagmp*/</script>
this is the line that passes the api key.
you would need to create a php statement to determine which api key should be used based on the $_SERVER["HTTP_HOST"]
switch ($_SERVER["HTTP_HOST"]) {
    case
"www.domain1.com":
$key = "key for domain 1";
        break;
    case
"www.domain2.com":
$key = "key for domain 2";
        break;
    default:
        break;
<script type="text/javascript"  src="http://maps.google.com/maps?file=api&v=2&key=<?php echo $key; ?>">/*wagmp*/</script>
dgwhit288523
Here is the script that I have put on the page
I am still getting error using this code - searaysundancer370.com You can view the source code on this page.
Where have I made the error?
Thanks,
Don
<script type="text/javascript" src="google_javascript/wagmp_map_1.js">/*wagmp*/</script>
case "www.searaysundancer370.com":
$key = "ABQIAAAAgwtnfPNsBdEuoMiz7NZqoBS4ZVxhru6LkDaeeOoNxAQuLVGqbxRZ7MIad5ZJjxL82oxdSH3m3LJ3uQ";
break;
case "www.94searaysundancer370.com":
$key = "ABQIAAAAgwtnfPNsBdEuoMiz7NZqoBToqOJDWkzYAxl4kqVz88eMNB2R6xSNBMF6R1rxfnb3YZBo47b
QXUDp7g";
break;
default:
break;
your page is a static html page, you cannot process PHP code on a static html page, rename the page using the .php extesnion:
directions.php
this assumes that your hosting plan includes php scripting.
dgwhit288523
Still Confused
I have two domains pointing to the one directions page which I have renamed to a .php page.
The keys for the two domains are as follows:
searaysundancer370.com :ABQIAAAAgwtnfPNsBdEuoMiz7NZqoBS4ZVxhru6LkDaeeOoNxAQuLVGqbxRZ7MIad5ZJjxL82oxdSH3m3LJ3uQ
94searaysundancer370.com: ABQIAAAAgwtnfPNsBdEuoMiz7NZqoBToqOJDWkzYAxl4kqVz88eMNB2R6xSNBMF6R1rxfnb3YZBo47bQXUDp7g
The primary key on which the htm page works is the first one.
The directions.htm page works fine with the following code for the searaysundancer370.com page.
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAgwtnfPNsBdEuoMiz7NZqoBS4ZVxhru6LkDaeeOoNxAQuLVGqbxRZ7MIad5ZJjxL82oxdSH3m3LJ3uQ">/*wagmp*/</script>
What should the new page renamed .php look like codewise using the two keys?
I am a real newbie at this and apologize for asking for some more help with this.
Thanks,
Don
the code should be:
    case
"searaysundancer370.com":
        break;
    case
"94searaysundancer370.com":
$key = "ABQIAAAAgwtnfPNsBdEuoMiz7NZqoBToqOJDWkzYAxl4kqVz88eMNB2R6xSNBMF6R1rxfnb3YZBo47bQXUDp7g";
        break;
    default:
        break;
but for this code to work, your pages will need to be saved as PHP pages.
dgwhit288523
Hi Jason!
Thanks for sending me the code. The page works fine now!
Don
you're welcome.
