Error messages when using the extension
Thread begun 7/29/2010 9:51 pm by tim122019 | Last modified 4/14/2011 8:24 am by Jason Byrnes | 4655 views | 5 replies |
tim122019
I get the following 3 error messages (repeatedly) when trying to use the extension.
While executing onMouseUp in wa_paypal.htm, the following JavaScript error(s) occurred:
At line 164 of file "Macintosh HD: Applications:Adobe Dreamweaver CS3:Configuration:Floaters:wa_paypal.js": TypeError: Buttons has no properties
While executing documentEdited in wa_paypal.htm, a JavaScript error occured.
An Error has occurred. Reference the error code below to resolve this issue at PayPal's website. Error Code: 11951
BUT I cannot find any information on "Error Code: 11951" at PayPal's website (I've tried.)
And I'm stuck in trying to use the extension. I did delete the Dreamweaver .dat file with your instructions, but I'm still stuck.
If you have already deleted the dat file then you may be experiencing a problem related to a corrupt config folder. If that is the case you will need to follow the instructions here to rename the folder:
showpost.php?p=12293&postcount=2
maryanne412094
I really appreciate the advice that has been presented with this problem. I've been having the same problem, however, I'm using CS5 and my error code line is 171.
I've removed the .dat file and opened dreamweaver again, only to get the same error.
After deleting the .dat file, I also get the following error: "While executing selectionChanged in wa_paypal.htm a JavaScript error occured
I renamed the configuration file like suggested and deleted the extension. Downloaded it again and ran it. I'm still getting the same error codes.
Any other ideas?
All help appreciated
If those two trouble shooting techniques did not resolve the problem this issue will need to be looked info further with you. I have opened a ticket for you on this issue, to update the ticket or check it's status login and visit your support history.
rastagod424700
issues with the Exyension
having an issue with the plugin mutiple errors regarding java script... and errors stating line 171... please advise
please post the exact error massage text so i can get a sense of the cause of the issue.
Have you tried deleting the Dreamweaver Cache file from the users configuration folder:
