how to add the css menu to dreamweaver's library
Thread begun 7/29/2010 9:02 pm by sorchard2000412016 | Last modified 8/02/2010 10:00 am by Eric Mittman | 1032 views | 1 replies |
sorchard2000412016
Does anyone know how to add the css menu navigation bar as a dreamweaver library item? I am getting an error that says it may not display correctly on other pages. Any ideas? Thanks
CSS Menu Writer will create some php code that has includes for the various files. The code that CSS Menu Writer adds to a page will only work properly if the paths are correct and the files exist in those locations. If the menu does not work for you you should check on these paths the the files to make sure they are were the code is looking for them.
