Theme It installation problem
I followed all the instructions (including get rid of that dat file in the "app" category) and Dreamweaver CS4 either crashes or won't open the Theme It extension for installation. Any suggestions?
Generally speaking when there is a problem with an installation I first suggest deleting the cache file.
If this does not work for you then you may need to rename your configuration folder and have DW recreate it for you. Here are the instructions for this:
showpost.php?p=12293&postcount=2
If you continue to have the problem please let us know and also include details about your OS and the extension manager you are using.
