Cookies toolkit error
Thread begun 7/29/2010 7:35 am by swolock397582 | Last modified 7/30/2010 6:54 am by Jason Byrnes | 3341 views | 5 replies |
swolock397582
I'm getting the following error when I try to Clear Session Values with Cookies Toolkit:
While executing onLoad in WACT_ClearSession.htm, the following JavaScript error(s) occurred:
At line357 of the file "(path to file):Applications:Adobe Dreamweaver CS4:Configuration:SharedWebAssist:Cookies:Library:WA_Configuration.js": getTagProp is not defined
How do I fix this? Should I uninstall Cookies Toolkit, delete that file and reinstall?
we have identified this as a compatibility issue with Security Assist and are working on a fix.
In the mean time, you can disable security assist in the extension manager t o get around the error.
swolock397582
Cookies Toolkit error
Thanks Jason. I'll give that a try.
you're welcome.
swolock397582
Create Log out page
So am I correct in thinking that to create a log out page all I need to do is create a page that says you've logged out and add the clear sessions values behavior to it? Or am I way off?
Exactly, you are spot on.
Set the trigger for the clear session value behavior to before page load.
