Dynamic Dropdowns 'Populate List from Array'
Thread begun 7/28/2010 4:13 pm by madmatmail408476 | Last modified 7/29/2010 9:46 am by Eric Mittman | 1533 views | 1 replies |
madmatmail408476
Hi, I have recently purchased this product and have managed to make it work a couple of times. On my most recent try, however it does not work. I have followed the instructions to the letter but when I get to 'Populate List from Array', it says:
Source and Target List: Select 'surgery' in form 'undefined' (where 'surgery' is a list/menu on my form).
How do I rectify this problem, it is stopping me progressing...
It seems like you may need to add a name and id to the form that you have these elements in, then you will also need to ensure that the select lists have their own unique names and id's as well. So long as you have the names and id's set properly you would then use this interface to select the source select or parent list, then select the target or child select list.
If you have any further trouble with this please post back with a copy of the page in question as well as a screen shot of the issue you are experiencing.
