Store Server Migration Broke the site
Thread begun 7/28/2010 10:59 am by carlene | Last modified 7/30/2010 1:30 pm by carlene | 6973 views | 15 replies |
carleneBeta Tester
Hi there-
I just recently migrated to another server. My server company handled the migration and moved all of the files and the databases and now the site is broken.
Yes I have updated the Connections files with the new IP address. Anything else I may have missed here that's causing the issue?
Thanks!
Carlene
you will need to edit the wa_settings table in the powerStore database.
make sure the root url is correct, you may also need to edit the Local root and remote root settings.
carleneBeta Tester
Hi - Yes the local URL is correct. Where are these other settings located and what should I be looking for exactly?
the the Local root and remote root settings are in the wa_settings table.
Perhaps a description of the issue would help me in determining what is wrong.
Please provide some details on exactly what is not working and a link where I could see the problem.
carleneBeta Tester
Jason,
The page is completely blank. This is what the error report says:
Warning: require_once(/var/www/vhosts/folkmanis.com/httpdocs/wholesale/storeConnections/WholesaleStore.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/vhosts/folkmanis.com/httpdocs/wholesale/store/WA_Globals/WA_Globals.php on line 37
Fatal error: require_once() [function.require]: Failed opening required '/var/www/vhosts/folkmanis.com/httpdocs/wholesale/storeConnections/WholesaleStore.php' (include_path='.:') in /var/www/vhosts/folkmanis.com/httpdocs/wholesale/store/WA_Globals/WA_Globals.php on line 37
make sure that the Root Url Setting in the database ends with the "/"
store/
instead of
store
that trailing slash at the end is important.
carleneBeta Tester
Hmmm.... I just checked in the wa_settings directory and the ending / is there. Where else could this error be found?
send a copy of the WA_Globals/WA_Globals.php file please
also check the Local Root and remote root settings in the wa_settings table. they should be:
/wholesale/store/
carleneBeta Tester
Thanks for your help Jason, yes both the local and the remote are /wholesale/store/
and I have the full URL in the Root URL field. I've attached the Globals file.
