Won't work in Firefox--please help this neophyte!
Thread began 7/28/2010 8:02 am by scanlan27458 | Last modified 7/28/2010 3:38 pm by Eric Mittman | 921 views | 1 replies |
scanlan27458
I have a form that is almost done.
ebpsaForm.php
It works beautifully but for one field, it is a set of radio buttons I set up
so that if Yes is clicked, a textarea pops up--and if No is clicked, the textarea does not pop up.
It works, it sends but it doesn't work and send in Firefox.
It is the radio group with the question
DO YOU WALK DOGS ON TRAILS ON OR OFF LEASH?
Any ideas--would like to keep it but not if it doesn't work in Firefox.
FireFox is reporting that there is an error on line 543. When I check the page source I see that this function definition is where the error is:
function displayTextBox()
var objElement = document.getElementById('YesTextBox');
YesTextBox.style.display = 'block';
YesTextBox.style.visibility = 'visible';
It seems to be complaining about the two lines in here that are setting properties of the YesTextBox directly. Since you are setting the objElement var to this checkbox you should be referencing that instead like this:
objElement.style.display = 'block';
objElement.style.visibility = 'visible';
Is this code that you added or modified yourself? If not please explain how you went about setting up this validation so that we can look into this further.
