Getting some weird email headings
Thread begun 7/28/2010 3:48 am by downloads336743 | Last modified 7/30/2010 9:57 am by Eric Mittman | 4274 views | 5 replies |
downloads336743
I created a form through contact form solution then wanted it styled (figured to use the form builder). I removed all the validations etc that contact form solution added as specified in the how to guide. And then it got re-added by form builder. It now works however the email i'm getting through has a lot of headings that I don't need, including it seems the captcha code etc. Can you help me remove this stuff. Thanks. The email content appears as below :
Contact me group Name: Test
Contact me group Email: sales@overloadweb.com.au
Contact me group Comments: test
Contact me group Security code: mrk
SimpleContact submit x: 35
SimpleContact submit y: 13
SimpleContact submit: Contact me
This is the result that you get when you use one of the template email pages when you craft your message. The page is looping over all of the posted values and using the name as the label for that value.
To have complete control over the contents of the message you can go to webassist > email > templates and open the template file. Once open go to Bindings > Form Data and select the page with the form on it. When you do this you will get the bindings for that form available to you on this email template page. Once you have these values in the bindings tab you can then add them directly to the page by dragging and dropping them where you would like them to be. This will be the value of that element that you drag onto the page, you can add in your own label to describe the value.
downloads336743
Hi Eric,
I assume you mean the templates email page (contactus.php) in the Universal email folder? If that IS what you mean, i tried what you said and came up with the following:
<html><head>
</head>
<body style="font-family: Arial, Helvetica, sans-serif;">
<div id="content" style="font-size: 12px;">
<h1 style="color: #777890;font-size: 14px;font-weight: bold;margin:0;">Contact Form Response</h1>
<hr style="margin:0;"/>
foreach( $_POST as $pkey => $pval ){
if ($pval != "" && strpos($pkey,"Security_") !== 0 && $pkey != "x" && $pkey != "y") {
<div style="formRow">
<strong><?php echo(str_replace("_"," ",$pkey)); ?>: </strong>
<?php echo(str_replace("\n","<BR />",$pval)); ?>
</div>
Name : <?php echo((isset($_POST["Contact_me_group_Name"]))?$_POST["Contact_me_group_Name"]:"") ?><br/>
Email : <?php echo((isset($_POST["Contact_me_group_Email"]))?$_POST["Contact_me_group_Email"]:"") ?> <br>
Comments : <?php echo((isset($_POST["Contact_me_group_Comments"]))?$_POST["Contact_me_group_Comments"]:"") ?>
</div>
</body>
</html>
The problem with that is that the email came back with :
________________________________________
Contact me group Name: Nic
Email : sales@overloadweb.com.au
Comments : test
Comments : test
Comments : test
Contact me group Security code: rs3
Comments : test
SimpleContact submit x: 48
Comments : test
SimpleContact submit y: 18
Comments : test
Comments : test
Any suggestions?
thanks
You are very close, the problem is that the loop is still there, it needs to be removed. The code on this page should be updated to be like this:
<html><head>
</head>
</div>
</div>
</body>
</html>
downloads336743
Ahh! Perfect. Thanks
Any idea when the fully integrated product will come out? So that we can create from scratch with Form Builder and send out without using other WA products and mess around with scripts like the above?
Cheers
Nic
It is in the works but I don't have a firm ETA on it. Keep an eye out for any new announcements or newsletters for more details.
