Hidden Email recipient
With Universal Email 4, is it possible to hide a dynamic email recipient? I do not want the sender to know the recipient's address until the recipient responds. Or is it easy to do with a code change? Thanks.
you can do this by adding the recipient in the BCC (Blind Carbon Copy) section.
As a followup to my previous email, bcc is not what I am after. This the hides sender's email address from the recipient, I believe, but not the sender. I would like to hide the recipient's email address from the sender. This way, the sender does not know the recipient's address unless the recipient chooses to respond. I am trying to preserve the anonymity of the recipient until he chooses to correspond.
I suspect that there may be a way to do this with a PHP email form, where I would not echo the recipient's address, but still get it from the database. I was wondering whether there was some functionality in Email 4 that would do this for me more easily.
Thank you.
the recipients address will still show in the to field or it would not be sent to them. If you are sending the same email to both parties, both addresses will show in the email headers.
