No code generated
Thread begun 7/27/2010 3:05 pm by nickj | Last modified 9/10/2010 7:58 am by Jason Byrnes | 4705 views | 10 replies |
nickj
No code generated
Server behavior for setting random password to set session variable fails to write code. I am now restarting DW and it will take more than two minuets to access the pages as the cace seems to need to be re-written every time I change sites.
Using CS5 on MAC 10.6.4
Nick
login.php
nickj
24 hour later and am stuck!
I have removed the DW configuration file, downloaded fresh extension and after a great many hour got back to the same problem. See the three attached images, when selecting the Random Password and even the defauilt values and clicking OK I get no code and the fourth image is the only message I get.
Please respond!
nickj
I've tried this on blank pages and on another MAC, it does not work.
nickj
Works on CS4 Does not work on CS5
cookie creator is not CS Compatible.
Have you updated your ticket with any of this information? Since the ticket has been opened for you on this issue you should make sure to login and visit your support history to update the ticket so that this issue can be looked into further with you.
nickj
Yes, three updates by me. Nick
See above, three responses, CS5 comparability!!!
I have seen your responses here and understand what you are saying. An engineer has responded to your ticket asking for contact info so that they can work with you on this issue to help get you past the problem. Please login and visit your support history to update the ticket.
klm0412257
Same Issue
Has this been resolved. I am having the same issue.
nickj
Sorry, no response. DWCS5 fails to generate the code in this one feature. At least on my MAC.
Nick
