Problems with get content from recordset
Thread begun 7/27/2010 9:10 am by Miguel | Last modified 8/12/2010 4:32 am by pmait97856 | 4030 views | 7 replies |
Miguel
Hello im trying to do a part where users have thier orders saved, when they return they can pay the amount they have saved in the order so i added a add to cart get content from recordset the only problem is that it only displays one product doesnt repeat the other products, help please why is this happening?
// WA eCart Get Info From RS
if ("" == "" && isset($totalRows_WADAorderdetails) && $totalRows_WADAorderdetails 0)     {
$Redirect_redirStr="";
  do     {
$SavCart_itemID floatval("".$row_WADAorderdetails['DetailProductID']  ."");
$SavCart_itemName "".$row_WADAorderdetails['DetailProductName']  ."";
$SavCart_itemDescription "".$row_WADAorderdetails['DetailProductName']  ."";
$SavCart_itemWeight floatval("0");
$SavCart_itemQuantity floatval("".$row_WADAorderdetails['DetailQuantity']  ."");
$SavCart_itemPrice floatval("".$row_WADAorderdetails['DetailPrice']  ."");
$SavCart_itemMainP "Fam";
$SavCart_itemExtra "";
$SavCart_itemuserP "";
$SavCart_itempaypal floatval("0");
$SavCart_itemporcentaje floatval("".$row_WADAorderdetails['porcent_det']  ."");
$SavCart_itemuserIDs floatval("0");
$SavCart_itemprecioUser floatval("0");
$SavCart->AddToCart(1""$SavCart_itemID$SavCart_itemName$SavCart_itemDescription$SavCart_itemWeight$SavCart_itemQuantity$SavCart_itemPrice$SavCart_itemMainP$SavCart_itemExtra$SavCart_itemuserP$SavCart_itempaypal$SavCart_itemporcentaje$SavCart_itemuserIDs$SavCart_itemprecioUser);
  } while (
$row_WADAorderdetails mysql_fetch_assoc($WADAorderdetails));
  if (
$Redirect_redirStr != "")     {
$SavCart->redirStr $Redirect_redirStr;
mysql_data_seek($WADAorderdetails0);
$row_WADAorderdetails mysql_fetch_assoc($WADAorderdetails);
Miguel
Any help why the list is not been populated correctly?
I have done some testing on this and with the same code that you have on your page I'm able to get all of the items from the recordset added to the cart. How many records are in your recordset that you are testing with?
If you can please post back with a copy of this order details table, this page in question, and your cart files so that I can do some testing to help determine what the problem might be.
Miguel
Ok ill past some screenshots
Ok screen 001-1 is a dynamic list with the users payments report wich orders has he paid or are waiting to be paid also if the payment was verified im using 2 checkouts one for bank transfer due to the big amount and others for paypal on this screen i selected the order #13
Screen 002-2 on this one i used a simple query to show what he has saved under that order wich he has not paid yet showing the items from the detail table with a repeat region at the end a simple botton that goes to the cart page
Screen 003-3 is the cart page i have 2 carts configured on the system one for ordering directly the user can pay or save for later payment and another one only exclusive for paying a saved order on the cart page i have a get content from recordset to display the orders saved under order 13 but it only displays 1 item instead of 2 same happens if there are even more items it only shows 1 item.
Screen 004-4 is the ecart settings wich i have when page loads it should fill the cart also before getting to this page any existing cart is cleared on the screen 002-2 with
    $savCart
->ClearCart();
    unset(
$_SESSION['Order']);
But no matter what i do it keeps showing only 1 item even if the order has more saved to it.
Screen 005-5 This is the setting i have for the query that should populate the cart its calling the details table filtered by order number ($_GET)
Hitting my head here cant seem to find what is wrong.
If you need access to the site please open a ticket or if you need the files
The add to cart from recordset should add all of the records to the cart. I would need to see your pages and data directly to get a better idea of what is occurring. I have opened a ticket for you on this issue so we can exchange details in private. To update your ticket or check it's status login and visit your support history.
pmait97856
Did you get this resolved, I am having the same problem
Hi Sades,
I get exactly the same problem. I am trying to add to the cart from a saved order template.
All the records show in the page but when I use the checkout button only the first record is added to the cart.
Regards, Paul
I looked up the ticket and here was the resolution that was listed:
from Ray
  The issue involved the order details having the same productid. We fixed it by adding a clear cart and updating the setting to always add new rows even when the id is the same... changed the 1 to a 2.
So it seems that the items were not being added because they did not have different item id's in the table. The update was to make it so that the item would be added even if the id was the same by updating the line of code in the add to cart that starts like this:
$eCart1->AddToCart(1, "", $eCart1_itemID, ...........
To be like this
$eCart1->AddToCart(2, "", $eCart1_itemID, ...........
A clear cart was also added just before this with this line of code:
$eCart1->ClearCart();
pmait97856
Thank you
Thanks Eric,
The solution worked.
Just a note for other users. I had a checkout button which was set to Update cart before checkout. What seemed to happen was that the records were put in twice.
Once I removed that everything worked fine.
Paul
