hash error (authorize.net error 99)
Thread begun 7/26/2010 9:32 pm by lilryansd360589 | Last modified 12/18/2013 11:41 am by Jason Byrnes | 7021 views | 12 replies |
lilryansd360589
Hello I am having the same exact error as related in this post,
showthread.php?t=7088&highlight=mhash
almost word for word so I will repeat some of it that directly relates to my problem.
I was originally having a mhash() error as described here:
show...ight=MHASH_MD5
I too found I have hash and not mhash installed on my server so in the file WA_simlib.php I changed
return (bin2hex (mhash(MHASH_MD5, $data, $key)));
to
return (bin2hex (hash(MD5, $data, $key)));
and this took care of the error, but now when I try my checkout Authorize.net gives me the following error:
(99) This transaction cannot be accepted.
I looked this up on Authorize.net and found:
tool...id=7199#bottom
When I go to this tool listed above and input all the required fields I am receiving a different hash for the x_fp_hash field.
Please let me know how to fix this or any other info that you may need.
Thank you for your time.
Ryan
login.php
av3103798
I'm having exactly this problem.
Is the solution posted somewhere? When I changed the line WA_simlib.php file:
to
I did get a value back in the error message from Chase Paymentech. But when I compared it to the one generated on their online "tool" to verify it, they were different. MD5 is chosen as on the hosting site.
thanks
doublecheck that the server supports the MD5 hash algorithem.
create a blank page with the following code:
print_r(hash_algos());
that will write a listing showing the algorithms tat are supported on the server, if MD5 is not listed, you need to contact the host to have them enable it.
av3103798
MD5 was listed
Hi Jason it is listed.
av3103798
info as requested
Thanks Jason.
see PM
av3103798
sorry
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
