Session Values being cleared
Thread begun 7/26/2010 4:04 pm by bjgarner241692 | Last modified 7/27/2010 10:17 am by Jason Byrnes | 3676 views | 8 replies |
bjgarner241692
Something about the Insert page that I am working with is clearing my Session Value and I cannot find it. I suspect it is normal behaviour however I am trying to adapt the DataAssist pages so that they only affect records for which the user has access.
The session value I need preserved is CID.
Please advise if you can help with this problem.
i suspect this line is the cause of your problems:
if (Request.ServerVariables("Request_Method") = "POST") then
Session("CID") = "" & cStr(cStr(Request.Form("Facility2"))) & ""
end if%>
this will set the session any time a form is posted, since the insert form does not have a Facility2 element, the session is being cleared.
bjgarner241692
hmm, that's not how I expected that to work.
Do you have a suggestion? I've tried On Page Load as well. Session works on that page (Insert) but is cleared on Insert.
I've even tried setting the value again on the Details page but it will not capture the value from the Insert page.
bjgarner241692
Found a work around. I was trying to populate a field on the Details page with the SessionID but I am able to get the same value from the Recordset.
It's a little clunkly but does function.
It would be nice to be able to set that Session value and have it survive the insert.
It looks like you are passing the CID session form the detail page to the insert page as a form value, this would only be needed if the insert page is on a different server.
The job of a session variable is to exist through out any page on your site once it is set.
you do not need to pass it from one page to another using a form.
bjgarner241692
Other way around.
Here's how it works.
First page is Insert page.
CID is set by taking the value from a form on a page that you do not have. CID is used to pull a recordset from DB1 to populate the Insert Form and ultimately a record in DB2. Works perfectly.
However, Insert goes to Detail page, where I still need the CID.
The code setting the CID on the Details page was added AFTER I found that my initial CID was being wiped out.
The workaround I came up with this morning was to insert a form at the bottom of Detail with one hidden field, populated from the WADA_Recordset and then Submit the form which loads Results page which pulls data from DB2 based on the CID. Works, I just don't like the form button at the bottom. The regular Results icon generated by DataAssist would be cleaner.
Thanks for your input.
so what page posts to the insert page that contains the Facility2 form element?
I guess you could add a hidden form element to capture the value being initially passed:
<input type="hidden" name="Facility2" value="<%=cStr(cStr(Request.Form("Facility2")))%>" />
bjgarner241692
It's a login page. It pulls Facility2 from the db because it is associated with the logged in user.
I will try the hidden field on the Insert page. I think that will work nicely.
Bart
ok, let me know if it does not.
