DataAssist Database Search Not Returning Results
Thread begun 7/26/2010 3:30 pm by stephanierjones133663 | Last modified 7/27/2010 8:09 am by Jason Byrnes | 5401 views | 9 replies |
Hello,
I am using CS5 and DataAssist 2. I am trying to perform a search that can have up to 5 parameters. When I set it up using my own search form and results, the "search" returned ALL THE RECORDS in the database. When I tried to have the extension create the page, form, and form field (testing using one text field with an EXACT MATCH attribute), everything in the database was still returned.
The WADbSearch folder is in the root of my site. If you need the connection file to my dummy database, I can give that to you.
the trigger for the search is looking for a form element named "WADbSearch1" to have a value.
add a new hidden form element to your search form, set the name to "WADbSearch1" and the value to "WADbSearch1"
Added Hidden Field and Still Did not Work
Hello, I added and it still did not work. Please see attached file. I started to get excited but am deflated... LOL! Thanks for helping me.
Better Image
Here is a better image of the page. I am using "jones" as a datapoint.
please compress the original search and results PHP pages into a zip archive and attach the zip file to your reply. Also include a link where I could see the problem.
Here is the link and a zip file.
Here is the link...
NewSearch1.asp
I am not using PHP. I have attached everything I have for that folder.
the forms method is set to get.
on the results page, change the following line:
if (cStr(Request.Form("WADbSearch1")) <> "") then
if (cStr(Request.Querystring("WADbSearch1")) <> "") then
Omg...
Oh my goodness!!!!!!!!!!!!!!!! Jason... Thank you soooooooo much!!!!!!!!!!!!!!!! You are da bomb!
One more thing...
I guess I forgot to tell you that IT WORKED LIKE A CHARM.
great, glad to hear it is working.
