undefined function
Im trying to add universal email to cms2 on the update page I got this
Fatal error: Call to undefined function microtime_float() in /home/va010021/public_html/daveLimo/admin/contents_update.php on line 111
This function is defined in the mailformatting_php.php file that should be included before the Universal Email code. If the file is in the root of the site the include path will look like this:
<?php require_once("webassist/email/mailformatting_php.php"); ?>
If you can see a require once line of code that includes this page make sure that it is above the UE code on the page and you should not have this problem.
