Access Rules Help
Thread begun 7/26/2010 12:49 pm by mark52139 | Last modified 7/26/2010 2:08 pm by Jason Byrnes | 1136 views | 1 replies |
mark52139
Access Rules Help
I used DataAssist to setup my - Insert, Results, Update, etc...
How would i setup a restriction that would only allow the user to view their page only.
I got the "Logged in to" to work o.k. but if a user logs in and get redirected to the results page - The results page - i setup a recordset to only show their record but the problem is if they would change url Update.php?id=3 to Update.php?id=2 they would see somebody else's record and could change it.
i tried to setup a Page access - like:
Allow
Value: <?php echo $row_WADAfreeparts['id']; ?> form field - id
Criteria: =
Compare to: <?php echo $_SESSION['id']; ?>
i always get an denied message.
the upate page should not rely on the querystring ID variable, it should use the $_SESSION['id'] value instead, this way there is no querystring to change.
