Multiple errors as a result of Search Wizard code.
Thread begun 7/26/2010 10:23 am by sandy259886 | Last modified 7/27/2010 8:07 am by Jason Byrnes | 1288 views | 1 replies |
sandy259886
I've tried several times to build this search. I'm cleared out the cache ... removed and reinstalled the extension. Still getting this problem. I'm now too frustrated to go any further.
The error(s):
Notice: Undefined variable: rsOrders in /home/sandyrumsey/public_html/ssl/_admin_pfg_10/orders_Srch/index.php on line 102
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/sandyrumsey/public_html/ssl/_admin_pfg_10/orders_Srch/index.php on line 102
Notice: Undefined variable: WADbSearch1 in /home/sandyrumsey/public_html/ssl/_admin_pfg_10/orders_Srch/index.php on line 103
Notice: Trying to get property of non-object in /home/sandyrumsey/public_html/WADbSearch/HelperPHP.php on line 381
Notice: Trying to get property of non-object in /home/sandyrumsey/public_html/WADbSearch/HelperPHP.php on line 395
My page sql code:
<?php require_once('../../../Connections/traders.php'); ?>
<?php require_once( "../../../WA_SecurityAssist/Helper_PHP.php" ); ?>
//WA Database Search Include
require_once("../../../WADbSearch/HelperPHP.php");
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../users_EmailPW.php");
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
mysql_select_db($database_traders, $traders);
$query_coupon = "SELECT * FROM coupons ORDER BY couponNum ASC";
$coupon = mysql_query($query_coupon, $traders) or die(mysql_error());
$row_coupon = mysql_fetch_assoc($coupon);
$totalRows_coupon = mysql_num_rows($coupon);
$query_affiliate = "SELECT * FROM affiliates ORDER BY AffiliateLink ASC";
$affiliate = mysql_query($query_affiliate, $traders) or die(mysql_error());
$row_affiliate = mysql_fetch_assoc($affiliate);
$totalRows_affiliate = mysql_num_rows($affiliate);
$maxRows_rsOrders = 45;
$pageNum_rsOrders = 0;
if (isset($_GET['pageNum_rsOrders'])) {
$pageNum_rsOrders = $_GET['pageNum_rsOrders'];
$startRow_rsOrders = $pageNum_rsOrders * $maxRows_rsOrders;
$query_rsOrders = "SELECT * FROM customers, orders, orderdetail WHERE customers.custID = orders.CustomerID AND orderdetail.orderID = orders.OrderId ORDER BY orders.OrderId DESC";
setQueryBuilderSource($query_rsOrders,$WADbSearch1,false);
$query_limit_rsOrders = sprintf("%s LIMIT %d, %d", $query_rsOrders, $startRow_rsOrders, $maxRows_rsOrders);
$rsOrders = mysql_query($query_limit_rsOrders, $traders) or die(mysql_error());
$row_rsOrders = mysql_fetch_assoc($rsOrders);
if (isset($_GET['totalRows_rsOrders'])) {
$totalRows_rsOrders = $_GET['totalRows_rsOrders'];
} else {
$all_rsOrders = mysql_query($query_rsOrders);
$totalRows_rsOrders = mysql_num_rows($all_rsOrders);
$totalPages_rsOrders = ceil($totalRows_rsOrders/$maxRows_rsOrders)-1;
$colname_rsaffiliateSession = "-1";
if (isset($_SESSION['affiliate'])) {
$colname_rsaffiliateSession = (get_magic_quotes_gpc()) ? $_SESSION['affiliate'] : addslashes($_SESSION['affiliate']);
$query_rsaffiliateSession = sprintf("SELECT * FROM affiliates WHERE AffiliateID = %s", GetSQLValueString($colname_rsaffiliateSession, "int"));
$rsaffiliateSession = mysql_query($query_rsaffiliateSession, $traders) or die(mysql_error());
$row_rsaffiliateSession = mysql_fetch_assoc($rsaffiliateSession);
$totalRows_rsaffiliateSession = mysql_num_rows($rsaffiliateSession);
$queryString_rsOrders = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_rsOrders") == false &&
stristr($param, "totalRows_rsOrders") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_rsOrders = "&" . htmlentities(implode("&", $newParams));
$queryString_rsOrders = sprintf("&totalRows_rsOrders=%d%s", $totalRows_rsOrders, $queryString_rsOrders);
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rsOrders;
//Searchpage: index.php;
//Form: srchForm;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromEdit("Date","startDate","AND",">=",2);
$WADbSearch1->addComparison("Date","".WAQB_getEndDate($_POST["endDate"]) ."","AND","<=",2);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_index"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_index"]) && $_SESSION["WADbSearch1_index"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_index"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
can you compress the original php file into a zip archive and attach that to your reply so I can see the code in context.
