Want to remove default user name and password from Admin/users_login.php
Thread begun 7/26/2010 10:17 am by janet259027 | Last modified 7/26/2010 5:14 pm by Jason Byrnes | 3016 views | 3 replies |
janet259027
I'm using your Registration Solution Pack and am trying to understand the code so I can modify/customize a few places (nothing major). Whenever I open the Admin/users_Login.php page the user name is automatically defaulted to "root" and the password is also set.
It appears as though it is getting this data from the connections/localhost.php file but I need that for the Database calls.
Is there someplace I can modify the code so that when this page is loaded the user name and password fields are blank?
the login form for the admin section of the user registration solution pack does not set a default value for the user name and pass.
If the form is being loaded with an initial value, this will be a browser issue, most likely when prompted by the browser at some point to remember the user name and pass for this domain, you selected yes.
test this theory by loading the login page in a different browser.
Most browsers offer a way to manage saved passwords, you can delete the password that is saved for the user registration domain.
janet259027
Thanks - I didn't even think about that. :-)
no worries.
