Redirect on Add to Cart not redirecting
Thread begun 7/26/2010 7:15 am by Gareth.TannattNash253613 | Last modified 7/27/2010 8:39 am by Jason Byrnes | 3626 views | 7 replies |
Hello,
Help I'm experiencing some fun in that the redirect on add to cart buton pressed is not redirecting, it merely refreshes the page?
my test & development design site can be seen here - flower.asp?id=1&Roses+S-delivered-in-Bortsmouth-by-Bortsmouths-premier-florist-Design+Florist+Site
(Please ignore the design as it is in development) and should once add to cart is pressed (on either product) should redirect to here -
cartso.asp?Bortsmouth=Florist
but it fails?
my code looks like this (part of)-
' WA eCart AddToCart
if (cStr(Request.Form("FloristWebCart_3_ATC")) <> "" OR cStr(Request.Form("FloristWebCart_3_ATC.x")) <> "") then
ATC_itemID = cStr(Request.Form("FloristWebCart_3_ID_Add"))
ATC_AddIfIn = 0
ATC_RedirectAfter = "cart/cartso.asp"
ATC_RedirectIfIn = ""
ATC_RSPos = ProductPrice3.AbsolutePosition
ProductPrice3.MoveFirst()
DO while (NOT ProductPrice3.EOF)
if (cStr(ProductPrice3.Fields("ID").value) = cStr(ATC_itemID)) then
ATC_itemName = "" & cStr((ProductPrice3.Fields.Item("Name").Value)) & ""' column binding
ATC_itemDescription = "" & cStr((ProductPrice3.Fields.Item("ProductDescription").Value)) & ""' column binding
ATC_itemWeight = cDbl("0")' column binding
ATC_itemQuantity = "" & cStr(Request.Form("FloristWebCart_3_Quantity_Add")) & ""' column binding
ATC_itemPrice = cDbl("" & cStr((ProductPrice3.Fields.Item("Price").Value)) & "")' column binding
Exit DO
end if
ProductPrice3.MoveNext()
Loop
ProductPrice3.AbsolutePosition = ATC_RSPos
if (IsNumeric(ATC_itemQuantity) AND ATC_itemQuantity <> 0) then
set FloristWebCart = FloristWebCart_AddToCart(ATC_AddIfIn, ATC_RedirectIfIn, ATC_itemID, ATC_itemName, ATC_itemDescription, ATC_itemWeight, ATC_itemQuantity, ATC_itemPrice)
if (ATC_RedirectAfter <> "" AND FloristWebCart_redirStr = "") then
FloristWebCart_redirStr = ATC_RedirectAfter
end if
Session("WAEC_ContinueRedirect") = cStr(Request.ServerVariables("Script_Name")) & "?" & cStr(Request.QueryString())
end if
end if
What have I missed?
Thanks in advance
please compress a copy of your page into a zip archive and attach that to your reply so I can see the entire page code in context.
Sure thing Page attached
Hi thanks for the response.
I've attached the page, I can attache the site if needbe?
Its an ASP VBScript page, I know that you guys only support PHP now, but when I bought Ecart ASP was supported too!!
It's not your standard page in that I'm using a lot of stored procedures, and whilst it is only displaying the one product, there are different size options (on a showif) so effectively different products and different recordsets to choose from.
Hope this is of use - and you can help -
Many thanks :-)
Your page is missing the following code blank that should be just before the doctype tag:
' WA eCart Redirect
if (FloristWebCart_redirStr <> "") then
Response.Redirect(FloristWebCart_redirStr)
end if
Great thank you.
any idea why it didn't get added automatically?
Cheers :-)
you're welcome.
I cant reproduce an instance where that code doesn't get inserted, so cannot guess why it wasn't in your case.
no problem - thank you anyway - very fast
you're welcome.
