need urgent help with html_entity_decode
Thread begun 7/25/2010 2:46 pm by roxcastaneda251760 | Last modified 7/26/2010 7:40 am by Jason Byrnes | 1366 views | 1 replies |
roxcastaneda251760Beta Tester
I have a form in spanish language, but it doesn't display the spanish characters, like "Ñ" or accents when it sends the email
Example:
<form action="" method="post" name="emailContact" id="emailContact" onsubmit="">
<div style="width:100%">
<label for="Contact_Name" >Your name:</label>
<br />
<span id="sprytextfield1">
<input name="Contact_Name" type="text" class="inputValue" id="Contact_Name" onblur="if (document.getElementById('nameServerError')) document.getElementById('nameServerError').style.display='none'" value="<?php echohtml_entity_decode(ValidatedField("contact","Contact_Name")) ?>" />
<span class="textfieldRequiredMsg">A value is required.</span></span>
<input name="addblock" type="text" id="addblock" style="display:none" value="" />
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span id="nameServerError" class="textfieldServerError">Please provide your name.</span>
<?php //WAFV_Conditional contact.php contact(1:)
I also need it in a checkbox group, but I don't know how to make it display properly when sending the email:
<label>
<input type="checkbox" name="Idiomas[]" value="Ingl&eacute;s" id="Idiomas_0" />
Ingl&eacute;s</label>
Please help!
to change the character set of the message that is sent, edit line 15 of the WA_UniversalEmail/WAUE_contact_1.php file:
$WA_MailObject = WAUE_Definition("".($WAGLOBAL_Email_Server)  ."","25","","","","");
$WA_MailObject = WAUE_Definition("".($WAGLOBAL_Email_Server)  ."","25","","","","UTF-8");
For the checkbox group, you will need to edit the WA_UniversalEmail/Templates/contact.php file. Change the following line:
<?php echo(str_replace("\n","<BR />",$pval)); ?>
<?php if(is_array($pval)) { ?>
echo(str_replace("\n","<BR />",implode(", ",$pval))); ?>
} else { ?>
