Not posting list info
Thread begun 7/25/2010 1:51 pm by wreilly338124 | Last modified 7/28/2010 11:37 am by Jason Byrnes | 4776 views | 13 replies |
wreilly338124
I have two issues, and they are probably linked.
1. I have created a form in CSS Forms and linked to UE4. Everything works, except that the information selected in either of my two lists are not included in the email that is sent.
2. The list themselves show a validation error and then lock up when they are selected in order. If they are selected first (out of order) they do not show the error.
I have used UE 3. doing the same thing and have not had a problem.
please post a copy of your page compressed into a zip archive so I can examine the code.
wreilly338124
Enclosed zip
Originally Said By: wreilly338124
Here is the zipped files. I tried achieving the same results using radio buttons and they work fine. I can't figure out where I've gone wrong.
1) to output multiple selections from a multi select list, you need to use the php implode function. for example:
<?php echo((isset($_POST["Quote_Request_Project_Info_Project_Type"]))?implode(", ",$_POST["Quote_Request_Project_Info_Project_Type"]):""?>
2) There are some unneeded script tags, delete the following code:
var Quote_Request_group_Please_select_the_option_that_best_describes_your_project_Spry = new Spry.Widget.ValidationSelect("Quote_Request_group_Please_select_the_option_that_best_describes_your_project_Spry",{validateOn:["blur"]});
var Quote_Request_group_Do_you_require_scriptwriting__1_Spry = new Spry.Widget.ValidationRadio("Quote_Request_group_Do_you_require_scriptwriting__1_Spry",{validateOn:["blur"]});
var Quote_Request_group_Video_Delivery_Spry = new Spry.Widget.ValidationSelect("Quote_Request_group_Video_Delivery_Spry",{validateOn:["blur"]});
var Quote_Request_group_What_is_the_projected_length_completed_run_time_of_your_project_Spry = new Spry.Widget.ValidationSelect("Quote_Request_group_What_is_the_projected_length_completed_run_time_of_your_project_Spry",{validateOn:["blur"]});
wreilly338124
Lists not posting
Yes, I did all that and retried it.
It still did not work. Also, if I made an entry error in the form to spark a validation error, when I go on to the list, they go black and lock up. However, if I select the lists first, there is no error, although they still don't post the info.
can you post a link to your site so I can see the problem.
wreilly338124
Link
Hii,
Here is the link.
quoterequest.php
Thanks.
i'm not able to reproduce the issue with the lists, they do not lookup for me when validation error are triggered on other form elements, I have tried this on a few different computers using IE, Safari and FireFox. I cannot reproduce the problem in order to troubleshoot the cause.
wreilly338124
Lists
Okay. I went to the site using IE8 and it immedietly locked up.
Also, that doesn't tell me about the problems of the lists not showing up when selected.
I have tried 3 different computer using IE 8 and cannot reproduce the problem.
Perhaps your browser is caching a bad version of the page? Try deleting the browsers cache.
for the list showing in the email, did you add the code I gave you to the email?
This is needed for multi select lists.
you will need to adjust the code for the other lists on the page.
If your still having a problem send a copy of the webassist folder.
