Artisteer
Thread begun 7/25/2010 7:27 am by ricardo396864 | Last modified 7/27/2010 10:27 am by Eric Mittman | 1696 views | 3 replies |
ricardo396864
Artisteer
Is the a way to use a customized template from Artisteer into PowerStore?
PowerStore is template based so you can make edits to the templates or you can make use of your own. However the elements within the PowerStore are designed to work in the default setup and it will require you to make these edits by hand and do extensive testing to ensure that you are not breaking any of the existing functionality. It might be easier to update the existing template with new art and images from another template rather than changing it out completely.
ricardo396864
Artesteer
Not trying to be a bother but i need a little more help than that. Do you have any video tutorials or know of any that can help me achieve this? i do not want to mess this up as i am new to this but learning it slowly but surely, thanks.
We do not have any documentation or video tutorials for making these changes. You could do quite a bit of customizing using just the css that is applied to the store or you can completely redo the design elements but it is not something that we support or have any documentation for.
