Data Assist Update record with images - does not return to details page
Thread begun 7/24/2010 4:51 pm by ingsercon21251 | Last modified 7/27/2010 11:31 am by Jason Byrnes | 2871 views | 7 replies |
ingsercon21251
Hello
I have a data assist update page with some pictures to be modified. All this upload and modification is working pretty good.
The problem is that after update the page should go to detail page, but it still in the same Update page.
I have checked the Update Server behavior and the location after update still there.
Like this : After Update go to:
Mem_vh_Dtl.php?VehicleId=<?php echo ((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:""); ?>
I will appreciate any help. I had been trying for almost 6 hours.
most likely a php error is occurring that is preventing the redirect.
Add the following code to line 1 to turn error reporting on:
error_reporting
(E_ALL);
post back the text of any errors that are occurring and copy of your page compressed into a zip archive so I can examine the code.
ingsercon21251
Here error message.
Thanks,
This is the error message I got.
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /hermes/bosweb/web184/b1848/ipw.digitec2007/public_html/vehimax2010/Mem_vh_Updt.php:5) in /hermes/bosweb/web184/b1848/ipw.digitec2007/public_html/vehimax2010/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at /hermes/bosweb/web184/b1848/ipw.digitec2007/public_html/vehimax2010/Mem_vh_Updt.php:5) in /hermes/bosweb/web184/b1848/ipw.digitec2007/public_html/vehimax2010/Mem_vh_Updt.php on line 341
php is sensitive to blank spaces between php tags.
at line 4, you blank space at the end:
and there is a blank line between php tags at line 9 and 297. These blank lines are causing the redirect to fail.
ingsercon21251
Jason
Thanks.
I actually did what you said but the problem still the same. Please see the error messages:
Warning: Cannot modify header information - headers already sent by (output started at /hermes/bosweb/web184/b1848/ipw.digitec2007/public_html/vehimax2010/Mem_vh_Updt.php:5) in /hermes/bosweb/web184/b1848/ipw.digitec2007/public_html/vehimax2010/Mem_vh_Updt.php on line 331
the headers already sent error means that there is output to the page before the header function or session-start function is being called.
the error:
is telling you that the output is at line 4 or 5 of the Mem_vh_Updt.php page.
if you cannot find the problem, send a copy of the page so I can see the code at line 4 and 5.
ingsercon21251
Jason
The instruction that controls the wa_security_assist process MUST have Spaces after and before the parenthesis. Like This
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
This was the problem. I got it working now.
Thanks for your help.
ok, glad to hear it is working.
