Community Toolbar Appearance and WebAssist Disappearance
Thread begun 7/24/2010 10:32 am by sidybus385412 | Last modified 7/26/2010 5:14 pm by Jason Byrnes | 1989 views | 3 replies |
sidybus385412
Two simultaneous problems:
When trying to "Edit Menu Theme" the beach ball (Mac) appeared.
After a bit of looking around the screen, hidden behind the WebAssist window, in the background, I found the following message pop up:
"COMMUNITY TOOLBAR - We're sorry, but the Safari browser version you are currently using does not support the community toolbar."
It was not until I hit the CLOSE button I could then continue editing.
Simultaneously, I found on my laptop (Mac) another problem: opening the same Dreamweaver files, WebAssist has completely disappeared. I re-downloaded and re-installed the extension. However, there is no little script visual from where I have been editing the menu - meaning that the Property Inspector for WebAssist does not apear.
Not sure if this is related - but I need fixes for both - especially the disappearing act on laptop!
the Community Toolbar is a rather vague, it can come from a number of places, like face book, or an other application. See the following thread for some details on posible things to look into to remove the comunity toolbar:
thread.jspa?messageID=10884545&#10884545
another option is to disable preview.
Go to Edit -> WebAssist Preferences, and check the disable preview option in the preview section.
To edit a menu, you will need to modify the Dreamweaver settings.
Go to edit Preferences. In the Invisible Elements section, make sure the scripts is checked.
sidybus385412
Thanks, Jason!
All your suggestions worked.
Monique
great, glad to hear it is working now.
