Purchases fail
Thread begun 7/23/2010 2:14 pm by 12.bernie410015 | Last modified 11/03/2010 10:00 am by Ray Borduin | 4227 views | 9 replies |
12.bernie410015
Purchases fail
I am using powerstore 3. This is a new install. I got a test set of information from authorize.net (credit card #s etc.) When I try to purchase a product in my store I get a message that purchase failed. I know I am using the correct authorize.net information.
Power store asks me for the CVC code which authorize.net did not give me. Could this be the problem?
this is on a Linux PHP5 system
John
Add the following code to your checkout failure page:
if(!session_id()) session_start();
 if(
$WAGLOBAL_Gateway == 1 ) {
     echo
"<p>Direct Pay: <br />";
     echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>";
     echo
"<p>Express Authorize <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />";
     echo
"<p>Express Process: <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Gateway == 2) {
     echo
"<p>Auth Net: <br />";
     echo
"Full Request: ".(isset($_SESSION['WAAuthNet_postedValues'])?htmlentities($_SESSION['WAAuthNet_postedValues']):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION['WAAuthNet'])?htmlentities($_SESSION['WAAuthNet']):"n/a")."<br /></p>";
  if(
$WAGLOBAL_Gateway == 3 ) {
     echo
"<p>Express Authorize: <br />";
     echo
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>";
     echo
     echo
     echo
 if(
$WAGLOBAL_Shipping == 1) {
     echo
"<p>UPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_UPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_UPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullResponse"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Shipping == 2) {
     echo
"<p>FedEX: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullResponse"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Shipping == 3) {
     echo
"<p>USPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_USPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullResponse"]):"n/a")."<br /></p>";
this will wrote the full request and full response to the page to help us see what the issue is.
NOTE: The full request and full response will contain sensitive information, any sensitive information should be removed before posting here.
12.bernie410015
Thank you for the diagnostic code it worked great. I am working with Authorize.net to fix some issues with my account.
John
you're welcome.
12.bernie410015
Follow up question
I have upgraded to PS 4.0. getting error message as before. Can I use the same diagnostic code in my checkout failure page?
Yes. The diagnostic code has not changed.
12.bernie410015
Transactions failing
Gentlemen,
When I post a transaction in PS test mode it works fine. When I take PS out of test mode and Authorize.net in testmode it fails with a message
"We're sorry
Your transaction could not be completed. Either your credit card information or billing address has problems and cannot be processed
Please return to checkout and try again."
I have the diagnostic code in place that you provided and the results are attached.
Can you tell me what is wrong.
As you can see I used the Authorize.net dummy CC numbers etc but I get the same results if I take Authorize.net out of test mode and attempt to run a live transaction.
I have tested from Authorize.net to our merchant gateway and that does work. It appears to be something between PS and Authorize.net.
The Authorize.net folks don't even see the transaction. The did tell me that the URL that PS should post to is transact.dll if that helps at all.
your help is appreciated.
We looked into this issue in a connect meeting. The security key was incorrect, and there was an "&" in the product description, which Authorize.net was rejecting.
12.bernie410015
Correction
Actually the security key was fine. We did generate a new one while on the call just to be safe. The ultimate fix was a bug in the code. The "&" was not being handled.
Do I still get billed for bugs?
By the way the gentleman that worked with me was great.
John
Please reply to the incident in question with a request for a refund and we can investigate it further. Issues that are a direct result of a bug should not be charged.
