Problems after install PowerCMS 2
Thread begun 7/23/2010 12:35 pm by admin140217 | Last modified 7/26/2010 3:19 pm by Eric Mittman | 3788 views | 5 replies |
admin140217
After several problems I have a good install of powercms 2 however I'm unable insert data for any page and it seems like I'm missing many images although they have been uploaded.
Admin login works but it's the following pages that don't.
When I click on Add Content I get the following error:
Page not found
The page you are looking for might have been removed,
had its name changed, or is temporarily unavailable.
Please try the following:
If you typed the page address in the Address bar, make sure that it is spelled correctly.
- Click the Back button in your browser to try another link.
- Use a search engine like Google to look for information on the Internet.
HTTP 404 - File not found
The URL it is going to is powercms/admin/common/contents_insert.php?ContentID=1
I could use some help to straighten this out.
The contents insert page should not be inside of the common folder, it should be located outside of the common folder in the admin folder.
There might be a problem with the way that the files were uploaded. You should backup the files that you have on your server now and re-upload them to ensure that they are copied to the server correctly.
If the problem still persists please post back and include any further details that you can come up with.
admin140217
Eric,
I checked the files that are on the server:
The common folder has 5 files in it:
addpage.php
contents_delete.php
listfolder.php
load_content.php
user_delete.php
The contents_insert.php file is in the admin folder outside of the common folder which is why I was confused about this. When I installed the CMS, I brought the entire folder over from my local machine using a fresh dowload from webassist to the server via FTP.
Do you think I should upload them again anyway or is this a path issue in one of the pages?
admin140217
update
Eric,
After looking into this more (more awake) I have found two things.
1. somehow a duplicate of the common folder wound up outside the admin folder. I renamed this folder to take it out of the structure.
2. most or all paths are wrong in regard to images and function such as the add content button.
I proved this out by looking at the image properties in the CMS while on the server and changed the path to what it should be according to the directory structure and the image did appear.
How can I make sure that all paths are correct for all pages in the CMS?
Does this require an install of all files again, if so how does that affect the database?
Thanks for your help
admin140217
update - fixed issue
Eric, thanks for replying to my comments, It looks like I have fixed the issue I was having.
Here's what appears to have happened.
In my last post I mentioned the paths looks messed up and that's true, all of the paths with exception of a few were but it was from the way I placed the files in my local directory along with renaming the file folder.
I had extracted the zip into the site directory and then renamed the file but it seems that the update process when renaming the file folder in Dreamweaver somehow changed the paths to all other folders, I'm still not sure why but it looks like what happened.
Later, I extracted all files to there own folder, then copied those files/folders to the powercms directory in the site structure, then copy and pasted those files into the directory to overwrite previous files. Then I proceded to upload all the files once again with the correct paths.
All seems to be working fine now including adding content.
That is good to hear. Sometimes if you have checked the box for 'update links automatically in other pages' DW will automatically change the paths to the resources based on where you move a page to. It is best to not have this option enabled if you would like to move pages around in the site without updating the paths.
Dynalux
CMS don't workafter installation
This post has been deleted.
