Static & Dynamic Recordset Menu Lists
Thread begun 7/23/2010 9:42 am by Thomas Hill | Last modified 7/26/2010 8:58 am by Thomas Hill | 3162 views | 5 replies |
Thomas Hill
I have created a dynamic menu list in Dreamweaver for users to select an item. Each of the items has it's own year category (up to 4 years) and has it's own order column. This way I can view all records and order them by year and order.
Although I have all this working great, can anyone tell me if there is anyway to add separate static lines within the menu at specific points to separate these elements so the user can see that the first few items are in year 1, the next in year 2 and so on?
If you see my attached image this should make it clear.
Many thanks.
P.S. I actually own all of the WebAssist plugins but am struggling with the implementation on this one.
CraigRBeta Tester
there may be other ways of doing this, but...
as each of the items has it's own year category, you could have the year category in a column in your recordset and concatenate this value in the display field, so, for example, the list could look like
(Year 1) Unit 1...
(Year 1) Unit 2...
(Year 1) Unit 6...
etc
Yes CraigR, that is the most strait forward way to accomplish this.
Thomas Hill
Many thanks for your replies. This does seem a good way to accomplish this.
However, is there anyway of creating the list with a single header for each year rather than place this besides each of the items as below:
----year 1----
Unit 1...
Unit 2...
Unit 6...
----year 2----
Unit 3...
Unit 4...
and so on....
Perhaps this is very complicated?
CraigRBeta Tester
One possible way of doing this, (i think ?) , but it would need to be hand coded.
You would need to created a separate recordset for each year group, 1-4
the year 'title' could be dispayed using <optgroup label="Year 1"></optgroup> tags aroung the dynamic data.
use a different recordset within each set of optgroup tags.
eg
<select name="xxxx" multiple>
do {
<option value="<?php ...RECORDSET FOR YEAR 1></option>
} while ...
</optgroup>
<optgroup label="Year 2">
do {
<option value="<?php ...RECORDSET FOR YEAR 2></option>
} while ...
</optgroup>
etc
</select>
...Another approach could be to use the parent/child relationship of dynamic dropdowns.
Use the first dropdown to choose the year, and the second (filtered) list for the relevant course.
This would, of course, depend on how a visitor selected their course
Thomas Hill
Thank you so much. This is EXACTLY what I was looking for.
Using this with the show if command as well really gives a great user experience.
Thanks again!
