Can't Access Powergallery
Thread begun 7/23/2010 7:03 am by larry268887 | Last modified 7/23/2010 4:36 pm by Eric Mittman | 3593 views | 6 replies |
larry268887
I'm using powergallery on a site that was created using site sculptor. When powergallery was first installed everything worked fine. Then the next time I needed to use powergallery I couldn't access it. I would get the following error Please login to access the requested page. So I reinstalled powergallery again and everything worked fine until the next time I needed to use it. I again reinstalled powergallery and changed the username and password thinking there may be some sort of conflict. Everything worked fine until the next time I needed to use it. Again it wouldn't allow me to login. I'm getting very tired of reinstalling powergallery.
It should be noted that I don't have any problems logging into the CMS system just powergallery.
here is the link admin/
Please help in finding the problem.
Larry
The PowerGallery login is based on the values that are in the wa_settings table. It might be that you have updated this table by installing the CMS that is created with Site Sculptor. Can you access your db directly? If so open it and take a look at the wa_settings table. In here you should see username and password values for accessing the admin area. Make sure that you have the same username and password that you are trying to login with.
CraigRBeta Tester
if you access the database directly, take a look in the wa_settings table, which will show you the admin_username and admin_password
larry268887
can't access pawer gallery
the password and the username is what is in the database. And this was verfied by the host also. Lets not see how many days this can take before I have to figure it out by myself.
The setting for powergallery is in the elvispowergallery database and the setting for the CMS is in the partiyorkie database.
The wa_settings table is correct in the partiyorkie database. The wa_setting table is complete and the username and pasword are correct but yet I can't log on.
The username and passwords are different for each database.
The hosting company has looked at this and said it is a programing problem not sure. But they looked at the problem and responded back within 1/2 hr. Lets not take days!!!
There is one thing that I know of that can cause this problem. Have you updated any of the Security Assist files in the PowerGallery area? The version of the HelperGroupsRulesPHP.php file that is included with PowerGallery differs from the one that would be created if you ran Security Assist or one from another solution. You should try re-uploading the original version of this file after making a backup of the current version to see if this resolves the problem.
I have opened a ticket for you on this issue in either case. If you can resolve the problem by re-uploading this HelperGroupsRules file there is no need to respond to the ticket. If that does not solve the problem for you then you can add to the ticket by logging in and going to your support history.
larry268887
Haven't updated any security assist files in the powergallery area.
Ok, I have seen an issue like this before where the file was not the default one and the result was very similar. If you have not tried to do so already you should backup your current version of this file in your gallery and try uploading the original.
The ticket has been opened for you and I think some additional info has since be requested by an engineer to help look into this further.
