DataAssist Redirect
Thread begun 7/23/2010 5:11 am by jim286478 | Last modified 7/26/2010 6:55 am by Jason Byrnes | 2762 views | 5 replies |
jim286478
DataAssist Redirect
Hi
In the page I have attached I am using dataassist to delete the last record from a MySQL table then redirect to another page, in this case publich.php. It works fine when I am on my local server however, in the actual server the record gets deleted then it shows the next last record instead of going to publish.php
I have not been able to figure out why it acts correctly in the local server but not in the actual server. Please help.
there are a few problems i can see on your page that would cause the redirect to fail.
1) Line 4 has a space at the end:
remove the space at the end of line 4.
2) line 109 is an unneeded close php tag. You can delete this from line 109.
jim286478
I took care of those errors but its still doing it. I have attached the new page for your review.
there is now a blank space at the end of line 3:
"if (isset($_SESSION["WADbSearch1_resultsallenhanced"])) unset($_SESSION["WADbSearch1_resultsallenhanced"]);?> "
remove the blank space at the end of line 3:
"if (isset($_SESSION["WADbSearch1_resultsallenhanced"])) unset($_SESSION["WADbSearch1_resultsallenhanced"]);?>"
jim286478
Thanks Jason that fixed it.
you're welcome.
