Reapeating table
Thread begun 7/23/2010 4:28 am by biesheuvel378713 | Last modified 7/23/2010 8:04 am by Jason Byrnes | 2149 views | 3 replies |
biesheuvel378713
Reapeating table
Well I'm paying around with data assist to learn all the features. Now I'm trying to build a repeating table but for some reason it doesn't work. I try to build a table form a record set but nothing shows in design or live view. I think it's just me, but if somebody would be so kind to look at the code so you can tell me what I'm doing wrong and how I get the table to display?
I also notice that setting classes to the alternating rows doesn't work properly.
Thanks in advanced..
CraigRBeta Tester
the first thing i notice is that your repeating table has no recordset data in it.
try adding a field from your recordset in line 88
biesheuvel378713
Also, I didn't noticed it at first the table was inserted in the head section. I added a field ('Name') and now the table looks alternates. But the number of rows is just three, it fills every column with the field name. horizontal to vertical.
I attached a photo and a file to show the script and results...
I'm not sure I understand, it seams to be working as expected. you have set the repeating table to have 3 columns:
$RepeatSelectionCounter_1_Iterations = "3";
That is what is shown in the screen shot.
