Shipping charges
Thread begun 7/22/2010 9:53 pm by kris348832 | Last modified 7/23/2010 4:34 pm by Eric Mittman | 1759 views | 3 replies |
kris348832
Shipping charges
I'm totally lost regarding the shipping side of things!
I'm a UK user and have been struggling my way through adapting it to UK currency etc, I'm nearly there, but could someone please point me in the right direction as to where to start setting up the shipping zones etc, is there a user guide or similar relating to this?
Many thanks
Kris
The shipping that is provided in the PowerStore is basic shipping quote info that is returned from one of the supported carriers. If you would like to add in your own custom shipping charges you would first need to make sure that you update the files for the cart to allow for this updating. Once you have done this you can then use eCart to create the new shipping charge rules that you need.
Before you create the new charge rules you will need to know how you would like to go about charging shipping including the circumstances and amounts. Once you have decided on your shipping charge criteria you can then implement the rules that will give you these results. If you have not seen it already the eCart support page has some resources on it that could help you, specifically there is a video on discounts that would help you understand how you craft these type of rules. Shipping, discount and charge rules all use the same interface and work the same way.
ecart/
kris348832
Ok thanks.
I do have ecart, though haven't used it as yet, time to dive in!
"If you would like to add in your own custom shipping charges you would first need to make sure that you update the files for the cart to allow for this updating"
Firstly how would I go about the above?
thanks
Kris
Sorry about that, I should have explained that part further. There is a known issue when modifying the PowerStore cart files in regards to the shipping. Jason has crafted an updated set of files that you can use that will fix this problem and allow you to edit and create your own shipping rules. Here is a link to the post with the updated files:
showpost.php?p=58360&postcount=3
