Is it possible to have 3 levels?
Thread begun 7/22/2010 5:08 pm by info410500 | Last modified 7/29/2010 10:12 am by Eric Mittman | 5055 views | 10 replies |
info410500
Okay so I have a problem.. I have level 1 which shows all my products
Product1
Product 2
Product 3
Each product then has it's own sub category after that I then want to have another sub category but they seem to show up under every 1st sub category
visit ScourPads
under the Products menu thats where the problem is
I have 3 tables setup, products, category and then subCategory
on the subCategory table I have SID, PID, CID which are SubCategoryID, ProductID and CategoryID but I cant seem to get the 3rd Menu to Show under 1 Product it starts to show subCategory information under every Product. Any code that can help fix this?
You can definitely have three levels of the menu in place. How do your level three items relate to the level two items? If your products relate to the sub category through an id field this should tie all of them together.
When you are adding the third level you need to specify the id column and choose to filter on the parent id and choose nested, so long as the filtered column you have selected matches the id of the previous level menu this should get you displaying the items.
We have a guide on this that can be found in the CSS Menu Writer support page:
mw2_creating_dynamic_menus_ht.pdf
info410500
I have 3 Tables
Okay so 3 Tables exist in my database
Category
Products
Sub Category
Category:
CID | Name
Products:
PID | CID | Name
Sub Category:
SID | PID | CID | Name | Description | Image
The Sub Category table is the issue
that's where the link has to be the link works perfect. The Sub Category or 3rd Level seems to show up under every product.
The key column is the SID but how should I filter it? by PID or CID Cause when I filter by either it doesnt seem to work correctly it either wont show up or shows up under every Product like I said. Really ball breaking lol but this week I have to complete it.
Luke
To make the level three menu work you must select the column in that table that holds the id from the previous table then select nested for the filtering. This will automatically filter out the third level menu items so that they relate to the id from the level two menu.
The normal relationship of information like this would be:
Category
Sub Category
Products
The table that you use in the level three menu must relate to the table used in the level two menu. You must select the id for the third table that corresponds to the id from the second table. Your tables data must fit the one to many model as it goes down.
Each record in the first table should relate to multiple records in the second table. Each record in the second table should relate to multiple records in the third table. If your data does not look like this then it will be difficult for you to have the menus setup like you have described. Please explain how these tables and records relate to each other with examples if you have any further trouble with this.
info410500
Database Relationships
AHh okay I understand how you mean.
The way the tables relate initially is by the CID then the PID For the sub categories like I said I have SID | PID | CID
The PID and the CID Relate to the correct fields and the SID is a unique auto_incremented number
Say for instance I have
1 | CategoryName in the Category Table
1 | 1 | ProductName Product Table
1 | 1 | 1 | SubCategoryName in the SubCategory table
The relationship is really by the CID and PID
Is that correct or wrong?
The relationship of the records in these tables must follow the one to many model that I outlined. So long as you have 1 category id that matches multiple products, then each product has multiple sub categories associated with it then your setup should work for you.
If you do not have multiple sub categories for each item then this will not work correctly. When you are going down the levels of menus each new level must have multiple entries that match it to the previous level. Do you have records like this in your tables?
Based on how you are describing your db and relationships I'm not sure if you will be able to create the menu you are looking for because I'm not sure if your setup follows along with the one to many relationship between these tables. If you have any further trouble with this please post back with a copy of the db in a .sql format in a zip archive so that I can take a look.
info410500
Okay
Yeah maybe you can fix it for me and post it back. Would much appreciate it.. been a big hassle with my knowledge here thanks
Luke
I was able to make the three levels of menu with your data without issue. What I did was setup the dynamic link for the categories table with no filtering. Next I setup the products as a sub menu of the categories. I specified to filter on the cid column, nested. Next I added the sub category sub menu to the products. I choose to filter on the pid, nested. This gives me a three level menu that lists all of the categories, then each product for that category, then each sub category for that product. In my testing I found that you had many categories but only the abrasives category has any products, and out of those products only abrasive belts had sub categories under them.
I'm including screen shots of what the interfaces look like for the contents of this menu so that you have a visual reference to go along with the description.
info410500
There We Go!
I knew it was something simple like that. Thanks again seems to work perfectly now :)
biz295654WebAssist
Extremely helpful discussion and screenshots. Thank you!
