Binding DataAssist field; error
Thread begun 7/22/2010 11:41 am by robcorrick409194 | Last modified 7/22/2010 11:50 am by Jason Byrnes | 1519 views | 1 replies |
robcorrick409194
I have created a search page using the wizard (public view). I have created a recordset, and all of my database fields are recognized. You can see a copy of my test behavior in the two files below. Is there any other binding that I should be doing?
In Live View, i receive the following error message "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE 0=0' at line 1"
The Where statement is actually on line 11. Here is some of the code:
<?php require_once('Connections/localhost.php'); ?>
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: Recordset1;
//Searchpage: ;
//Form: ;
$WADbSearch4_DefaultWhere = "WHERE 0=0";
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WADbSearch4 = new FilterDef;
$WADbSearch4->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch4->addComparison("Role","".((isset($_GET["S_Role"]))?$_GET["S_Role"]:"") ."","AND","=",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch4_users_Search"]=$WADbSearch4->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch4_users_Search"]) && $_SESSION["WADbSearch4_users_Search"] != "") {
$WADbSearch4->whereClause = $_SESSION["WADbSearch4_users_Search"];
else {
$WADbSearch4->whereClause = $WADbSearch4_DefaultWhere;
else {
$WADbSearch4->whereClause = str_replace("\\''", "''", $WADbSearch4->whereClause);
$WADbSearch4whereClause = '';
if (PHP_VERSION < 6) {
I would appreciate any help. Thank you.
change the default where clause from "WHERE 0=0" to "0=0"
