how to remove validations from a field in the Contact Form
Thread begun 7/22/2010 8:44 am by skyll237680 | Last modified 7/22/2010 11:40 am by Dani Chankhour | 1447 views | 1 replies |
skyll237680
I am trying to remove a "required" server validation from the "Company Name" field on the form in the Contact Form Solutions Pack. I have the Validation Toolkit extension.
I clicked on the WA Server Validations in the Server Behaviors panel. I located the "Company Name" field with the "required" validation that I wanted to remove. I selected it and clicked the minus button. I saved the page and re-uploaded it. When I filled out the form and left the "Company Name" field blank, the JavaScript error message appears saying it is required. I realized that I needed to also remove the client side behaviors, but when I looked int the Behaviors panel, it was empty, nothing there to remove?
I've searched around looking for instructions how to remove the JavaScript client-side validations, but I must be missing it somewhere. I've tried to remove the code manually, but I think I am not doing it right, because the form page is blank when I try to upload it, so I go back to the page I saved before I modified it to try to start over trying to do it right. Could someone point me in the right direction?
Thanks so much!
Dani Chankhour
You will need to click on the form tag, and then all the validation will show under the Behaviors Panel.
