Using PowerCMS with Fatcow servers
Thread begun 7/22/2010 7:23 am by admin140217 | Last modified 7/27/2010 6:52 pm by Dani Chankhour | 5951 views | 9 replies |
admin140217
Hello,
I have created a database and uploaded my PowerCMS files into a folder called CMS on the host server /CMS/ but I'm getting an HTTP 500 error when I call up CMS/ for the install.
Why would this happen on a fresh upload?
I don't know if it has anything to do with Fatcow but that is where everything is located.
Any help would be great.
Dani Chankhour
I don't think it has any thing to do with the server, but just make sure that you have the right domain typed in in the URL. as a test, create a test html page and place it under the cms folder and see if you can browse to it. If you are not able to browse to the html page then the url that you are using is incorrect.
admin140217
Dani,
I'll try your suggestion thanks. I have already created a new folder in the sites root and that seems to be working fine. I'll see what happens.
admin140217
This is an update. If I use Firefox I get some progression in the url but the install does not occur and trys to go right to the user log in.
admin140217
update
I decided to do a fresh install and got the same result, the install did not occur, didn't even start. I did what Dani suggested and put a simple html file in the /powercms/ directory (I used the read me file that came with the cms) and that file came up no problem, so I know the URL is correct.
So this leads me to my original question, is this something on Fatcow servers that is preventing the install? Maybe a permissions issue?
I tried changing the permissions on the powercms folder and did get an error message but the install still did not happen.
Why would nothing happen?
the url is here: index.php
This is getting serious now.
admin140217
update 2
I chatted with Fatcow tech support and they said it's a coding issue in the script.
when I go to meyershouseofsweets.com/powercms/index.php it is now giving me this error:
Warning: require_once(../../rename_and_upload_this_folder/WA_Globals/WA_Globals.php) [function.require-once]: failed to open stream: No such file or directory in /hermes/web01b/b1067/moo.scmeyer/powercms/admin/users_login.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../rename_and_upload_this_folder/WA_Globals/WA_Globals.php' (include_path='.:/usr/local/lib/php-5.2.12/lib/php') in /hermes/web01b/b1067/moo.scmeyer/powercms/admin/users_login.php on line 1
It seems as though it is not going to the install folder but to the admin user login, theURL it is redirecting to is:
users_login.php
So why is the install failing on the server, the powercms version is 2.0.1
I'm in need of help on this one.
admin140217
update 3
A fresh install did it. When the folder was renamed, not all the references where changed and caused the install not to work properly.
I have now had a successful install but many of the images are not there and was not able to insert content.
Still working on it.
Dani Chankhour
What images are you referring to? are they the images in the solution or are the images that you have inserted.
In regard to inserting a content, are you getting an error, or what exactly is happening when you click the insert button.
admin140217
Dani,
This is all set now. It was a path issue caused by the way I had put the files into the site's directory.
Dani Chankhour
I'm glad you were able to get it working.
