Gallery Width
Thread begun 7/22/2010 7:12 am by rob294118 | Last modified 7/22/2010 12:42 pm by Dani Chankhour | 2396 views | 5 replies |
rob294118
Gallery Width
Where do I change the gallery width? I have a website that is 960 px. The gallery is too wide.
Thanks.
Dani Chankhour
In the PowerGallery folder, there is a galleries folder and under each gallery there is a css file. The file you need to update is the common css file. However, you might need to make additional changes to the dark or light css file depending on the gallery.
rob294118
Which Setting
Which setting to I change?
Dani Chankhour
at the top of the page in the common css file there should be a class:
.pg-gf {
width: 896px;
font-family: Arial, Helvetica, sans-serif;
try changing the width to something smaller. If you need further help please post a link with the gallery to further assist you.
rob294118
It doesn't work. I changed the value to 600px and I see no change.
Link: gallery.php
Dani Chankhour
OK, Like i said there could be other changes you have to make. You will also need to update the width under these classes:
.pg-rfl .fullsize, .pg-rfl .title
let me know once you made these adjustments to see if we need to make any further changes.
