Update doesn't work
Thread begun 7/22/2010 3:39 am by biesheuvel378713 | Last modified 7/22/2010 1:49 pm by Jason Byrnes | 3322 views | 5 replies |
biesheuvel378713
Update doesn't work
When I create pages with the Data Assist wizard the update doesn't work. If I try to update a reacord I get this message:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@chello.nlundefined WHERE `ID`=2' at line 1
Where ID is the primary key, am I doing something wrong or can I change some code somewhere?
CraigRBeta Tester
can you post your page code or the select statement.
there is an error in the sql syntax causing your problem
biesheuvel378713
Here is the code for the update page, if you need more please let me know...
<?php require_once('Connections/phptest.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$ParamID_WADAda_user = "-1";
if (isset($_GET['ID'])) {
$ParamID_WADAda_user = (get_magic_quotes_gpc()) ? $_GET['ID'] : addslashes($_GET['ID']);
mysql_select_db($database_phptest, $phptest);
$query_WADAda_user = sprintf("SELECT ID, Name, LastName, email FROM da_user WHERE ID = %s", GetSQLValueString($ParamID_WADAda_user, "int"));
$WADAda_user = mysql_query($query_WADAda_user, $phptest) or die(mysql_error());
$row_WADAda_user = mysql_fetch_assoc($WADAda_user);
$totalRows_WADAda_user = mysql_num_rows($WADAda_user);?>
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = $phptest;
$WA_table = "da_user";
$WA_redirectURL = "da_user_Detail.php?ID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_keepQueryString = false;
$WA_indexField = "ID";
$WA_fieldNamesStr = "Name|LastName|email";
$WA_fieldValuesStr = "".((isset($_POST["Name"]))?$_POST["Name"]:"") ."" . "|" . "".((isset($_POST["LastName"]))?$_POST["LastName"]:"") ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$WA_columnTypesStr = "undefined|undefined|undefined";
$WA_comparisonStr = " = | = | = ";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_phptest;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
<head>
<title>Update da_user</title>
<link href="WA_DataAssist/styles/Ultramodern_Nautica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAUpdateContainer">
<?php if ($totalRows_WADAda_user > 0) { // Show if recordset not empty ?>
<form action="da_user_Update.php?ID=<?php echo(rawurlencode($row_WADAda_user['ID'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
<div class="WADAHeader">Update Record</div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">ID:</th>
<td class="WADADataTableCell"><?php echo(str_replace('"', '&quot;', $row_WADAda_user['ID'])); ?></td>
</tr>
<tr>
<th class="WADADataTableHeader">Name:</th>
<td class="WADADataTableCell"><input type="text" name="Name" id="Name" value="<?php echo(str_replace('"', '&quot;', $row_WADAda_user['Name'])); ?>" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">LastName:</th>
<td class="WADADataTableCell"><input type="text" name="LastName" id="LastName" value="<?php echo(str_replace('"', '&quot;', $row_WADAda_user['LastName'])); ?>" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">email:</th>
<td class="WADADataTableCell"><input type="text" name="email" id="email" value="<?php echo(str_replace('"', '&quot;', $row_WADAda_user['email'])); ?>" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Update" id="Update" value="Update" alt="Update" src="WA_DataAssist/images/Nautica/Ultramodern_update.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="da_user_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Nautica/Ultramodern_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAUpdateRecordID" type="hidden" id="WADAUpdateRecordID" value="<?php echo(rawurlencode($row_WADAda_user['ID'])); ?>" />
</div>
</form>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAda_user == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">No record found.</div>
</div>
<?php } // Show if recordset empty ?>
</div>
</body>
</html>
mysql_free_result($WADAda_user);
in the future, please compress the php file into a zip archive rather than pasting the page code, it is easier to read that way.
The data types in the update record behavior are not set correctly.
Double click the update record behavior and make sure that the data type for each of the columns is set to text.
biesheuvel378713
Thank you for the quick reply, now I know what to do.
When setting the data type for each column I have to set one column at a time and then press back and next to set the next column. That's why the data types where not set correctly, so it's a litle error in the dialog.
For the rest it's a fine product!
(Next time I will send a zip)
glad to hear it is working.
