Data assist: Inserting multiple records
Thread begun 7/22/2010 2:38 am by biesheuvel378713 | Last modified 7/22/2010 2:38 am by biesheuvel378713 | 991 views | 0 replies |
biesheuvel378713
I've always worked with ASP.NET but now I've started to learn php. I've bought data assist and it's a great tool.
I have an idea with the option for inserting multiple records. I've build a form with Data assist to insert multiple records. Then I've adjusted the form so every box gets validated with spry and before inserting the records it asks how many new records should be inserted.
Wouldn't that be a great feature in Data assist itself?
For example, if a table has a column for email addresses it would be nice if there is spry validation so the user always inserts the right address and will be prompted before inserting it into the database. It would also be much more sense if the user could first decide how many new records it wants to update.
In itself it's not very hard to adjust the code so this will all happen but it would be great if you could do it straight form data assist.
But it is a great tool, I 've just started working with it and its a real pleasure....
