thankyou.php redirect header
Thread begun 7/21/2010 10:28 pm by bbg5101409933 | Last modified 7/22/2010 11:50 am by Jason Byrnes | 3733 views | 7 replies |
bbg5101409933
What is the purpose of redirecting to the thank you page only if "index.php" is not blank?
In other words, in "contactus.php", within the following code:
//Send Mail All Entries
if ("index.php"!="") {
header("Location: thankyou.php");
what is the purpose of
if("index.php"!="")
This is the only part of the code that's given me trouble, so I'm trying to better understand the significance of basing the redirect on a page that doesn't exist ("index.php").
Thanks!
it is only a string comparison used to determine if the header function should be used at all.
This is code generated by the Universal Email extension.
In the extension you could leave the redirect blank. if you do, that code would be written as:
if ("" !="") {
header("Location: ");
If the if statement where left out in this case, it would generate an error due to the missing parameter in the header function.
bbg5101409933
That makes sense. The only part I don't understand is why the "if" statement is checking against a file ("index.php") that doesn't exist. Does this file exist in the Universal Email extension?
it's not checking the file. it's checking the string.
the if statement could be
if("dog" != "")
or:
if("dog" != "cat")
it's string comparison, that just happens to use the string "index.php".
it's not checking for the existence of the file, just that the first string ("index.php") is not the same as the second string ("")
bbg5101409933
That clears it up. Thanks.
One last thing: What purpose does the string comparison serve? Why not just call the header alone?
I'm not doubting it's use. I'm just trying to understand it better.
bbg5101409933
Thanks for all your help!
you're welcome.
