MenuWriter_SR-SupportFiles
Thread begun 7/21/2010 12:43 pm by stprix49407889 | Last modified 7/21/2010 2:42 pm by Dani Chankhour | 1110 views | 1 replies |
stprix49407889
Hi!
What is a Solution Recipe Support Files? Are Solution Recipe for creating or modifying the design of a menu or something else? Are these only for dynamics sites or also for static sites? What is the purpose of using the "customizing CSS Menu Writer Menus"? Is that something I have to install in my DW?
Serge
Dani Chankhour
Solution Recipes: Support Files are just set of files that you will need to follow our solution recipes which will help you cover one aspect of using the Extension. Each of the solution recipe include a PDF file which will guide you in completing the solution recipe using the files in the Support Files folder.
For example the "Customizing Menu Writer Menus" solution recipe will help you set different background images for the menu buttons.
You should not have to install any additional extension in DW as long as you have MW installed and a site defined. Some of these solution recipes might require a php site and others could be applied to static site.
let me know if you still have any other questions.
