Adding Add to Cart on other pages
Thread begun 7/21/2010 11:49 am by david403594 | Last modified 7/23/2010 12:25 pm by Jason Byrnes | 3509 views | 5 replies |
david403594
I have other pages on my site (php) and I'm looking for a way to place a Add to Cart button for products within my powerstore. Is there a way to do this?
Dani Chankhour
if you own the eCart extension, then you should be able to add add to cart buttons to other pages on your site.
david403594
Documentation?
I tried simply adding the Add to Cart button via eCart but it seems to only give me the static option. How do I make it work with Powerstore???
Is there any documentation that covers this? I looked but didn't see anything that was clear.
Dani Chankhour
If you only got the static information, then you either don't have a record set on your page or you don't have a dynamic site defined. If you don't have php site defined this link will guide you in setting up a php site in DW:
dynamic_site_definitions.php
once you have that make sure to add a record set to your page.
david403594
Still having problems...
It seems like my mamp is working okay. If I just look at a plain php page that I've created it comes up fine. When I go to the directory where my powerstore is located it's coming up blank.
I hate bother you guys with this I'm just trying to get it all figured out. I really need to be able to add the Add to Cart buttons on my site. Can you please help?
Thanks again in advance.
btw - I went step by step through the setup link you sent.
To be able to edit the PowerStore pages using Dreamweaver, the PowerStore files must be at the root of the Dreamweaver site.
