Powerstore3 and using eCart 5
Thread begun 7/21/2010 12:44 am by hans334173 | Last modified 7/22/2010 7:06 am by Jason Byrnes | 2709 views | 3 replies |
hans334173
After a perfect installation(compliments) i try to make changes in the eCart using eCart 5, after upload my index.php is totaly empty. I must be doing something wrong.
editing the cart with eCart will cause the shipping rules code to be written incorrectly, see this post for a fix:
showthread.php?t=12820
hans334173
eCart problems
Thank you very much. The solution you offerd worked perfectly.
Still, if i change the eCart setting to Dutch en Euro nothing changes realtime. I never had that problem in the previous PowerStore.
Do i need to install languages packs or something?
With regards,
Hans van der Velde
we do not support changing the currency. You would need to change the currency symbol directly in the code.
