UE Syntax error
Thread begun 7/20/2010 5:28 pm by david331670 | Last modified 7/27/2010 12:13 pm by Jason Byrnes | 3124 views | 6 replies |
david331670
UE Syntax error
When I try to checkout withPayPal Express, PayPal takes the money but I get a browser page error: Parse error: syntax error, unexpected '}' in ....../webassist/email/WAUE_pp_confirm_1.php on line 174.
I have look at this area on a number of different WAUE.php pages and they all are different in some way or another, I cant find consistency in the code. The very similar setup for the PayFloPro checkout page works ok and it looks the same. I dont get any errors.
Can you let me know what the problem may be please
Thank you
David
Copy of area below:
Its the curly bracket, I have marked the line 174 by "THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174"
//WA eCart Merchandizing Show End
//ecart="Spectrum_online"
$MailBody = $MailBody . "\r\n";
$MailBody = $MailBody . " <tr>\r\n";
$MailBody = $MailBody . " <td style=\"text-align:left; font-weight:bold; padding: 10px 14px 10px 5px; background-color:#E5F385; /* Accent_11 */ border-top:solid 1px #CCD0D6; /* Neutral_Medium */ \" >Total:</td>\r\n";
$MailBody = $MailBody . " <td style=\"background-color:#B8D249; /* Accent_12 */ width:15%; text-align:right; padding: 10px 14px 10px 5px; border-top:solid 1px #CCD0D6; /* Neutral_Medium */\" >";
$MailBody = $MailBody . WA_eCart_DisplayMoney($Spectrum_online, $Spectrum_online->GrandTotal());
$MailBody = $MailBody . "</td>\r\n";
$MailBody = $MailBody . " </tr>\r\n";
$MailBody = $MailBody . " </table>\r\n";
$MailBody = $MailBody . " </div>\r\n";
$MailBody = $MailBody . " ";
//WA eCart Show If Middle
} THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174 THIS IS LINE 174
else {
$MailBody = $MailBody . "<table><tr><td>The cart is empty</td></tr></table>";
//WA eCart Show If End
$MailBody = $MailBody . " \r\n";
$MailBody = $MailBody . "<div style=\"font-family:Verdana, Arial, Helvetica, sans-serif; /* Font Style */ font-size:x-small; color: #2C2D2E; /* Neutral_Black */ width:514px;\">\r\n";
$MailBody = $MailBody . " <div style=\"border-bottom:solid 1px #BABDC2; /* Neutral_Dark */ padding-bottom:10px;\">\r\n";
$MailBody = $MailBody . " <h3 style=\"font-size:small; background-color:#F1F0EE; /* Global_Gray_Light */ color: #353C48; /* Accent_5 */ padding: 5px 7px; margin-bottom:7px; border-top:solid 1px #BABDC2; /* Neutral_Dark */ border-bottom:solid 1px #BABDC2; /* Neutral_Dark */\">PayPal Express Checkout Information</h3>\r\n";
$MailBody = $MailBody . " <div>\r\
please compress the /webassist/email/WAUE_pp_confirm_1.php file into a zip archive and send that so i can see the code in context.
The error is saying that the "}" is not necessary because there is not a matching "{", but there should be a matching "{".
I will need to see the entire page code to determine what is wrong.
david331670
Waue
Jason
Here is the zip'd file.
I tried to recreate the file by making a small edit to the html in dreamweaver and re-save the WAUE file, uploaded to the web site but got the same result.
I am still confused why WAUE creates so much code that I need to remove to get the system to work.
Thanks again
David
the code that starts the loop through the cart to display each line item had been removed.
I am sending a fixed copy of the file.
david331670
Waue
Jason
I have copied the code you supplied to my page.
I now have another syntax error:
Parse error: syntax error, unexpected T_OBJECT_OPERATOR in /usr/home/spect7/www/htdocs/webassist/email/WAUE_pp_confirm_1.php on line 58
Line 58 is "while (!Spectrum_online->EOF()) { "
Can I easily regenerating the the entire page?
Please help.
David
david331670
pp_confirm syntax error
I have fixed the page.
I have replaced the script from WAUE 3&#8230;
It now works????
Is it easier to rewrite the page and hence the email script?
Just a thought
Regards
David
Yes, it may be easier to recreate the page from scratch using Universal Email 4.
